So if I get the progressive controller....
Old Sep 19, 2002 | 12:44 AM
96z's Avatar
96z
Im thinking about getting nitrous strapped on this winter and I planned on having the safety equip. Window switch, purge, blow down tube, etc.
If I got the progressive controller would I be able to go without anything? I just dont want to buy the same thing twice.
Old Sep 19, 2002 | 07:45 AM
rskrause's Avatar
Moderator
We should talk about this! If you are thinking about the very promising "Perfect Power" piece the answer is "no", in theory it would make a window switch completely unnecessary. It wouldn't take the place of a FPSS, but most people don't have these anyway.
However, it hasen't been used on a 4th gen to date that I am aware of. Depending on a few other things (mostly on if I get a "real" race care this winter) we may try it out on my Camaro this winter.
I don't know much about other types of controllers.
Rich Krause
Old Sep 19, 2002 | 08:42 AM
RacinLT1's Avatar
Im running the NX Maximizer (progressive). It doesnt take place of any of the other "safety items".
I dont run a window switch or a fpss,but those are things i have never used in 8+ years of nitrous.
My trans is built,so i spray through the shifts,and im running a 255 in tank fuel pump.
If it's your first time,i would recommend going with all the normal safety stuff (better safe than sorry).
Glimmer's Avatar
I´m sorry, but I´ve seen the term "window switch" everywhere, but what does it mean? You have to excuse me, but I´m only a simple Swede
Old Sep 19, 2002 | 08:53 AM
RacinLT1's Avatar
Basically a window switch is an rpm switch that has a low and a high set that is set by the user. It only allows something to "turn on" (ie: nitrous in this case).
Some have "pills" while the other uses a digital readout and pushbutton setup.
Old Sep 19, 2002 | 11:22 AM
96z's Avatar
96z
Ok than, I wasnt sure about the progressive controller.
What safety items should I get than?
Window switch,
FPSS
Old Sep 19, 2002 | 09:43 PM
gb95zconv's Avatar
Window switch,
FPSS
Ild recommend a bottle heater to keep your nitrous pressure right.
As far as the controller goes its not really for safty. Its more for hooking up. By dialing in the controller I was able to cut 3 tenths off my 1/4 time. It allows you to control how big of an initial shot you get and how quickly it rises to 100% and a few more time and power options.
Old Sep 20, 2002 | 12:02 AM
Glimmer's Avatar
Ah, thanks.
Quickss96
Jan 29, 2016 05:56 PM
marlar98
Sep 19, 2015 07:53 AM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Aug 21, 2015 07:20 PM
NewsBot
Aug 17, 2015 11:40 AM
