auto gears in manual
Old Jul 12, 2003 | 11:22 PM
kingman109's Avatar
okay i know stupid question but wanna make sure...im gonna be swapping to a 5 speed and changing out my rearend to posi as well as doing a 383 build...just wondering if the auto gears will be able to be used with the manual... aka switch gears in the rear ends
Old Jul 12, 2003 | 11:52 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
all 3.4L's have 3.23's stock
Old Jul 13, 2003 | 03:06 PM
kingman109's Avatar
umm....okay but not my question..thanx though...im swapping rear ends with a 95 lt1 from a 5 speed... now correct me if im wrong but a manual has smaller gears... 2.73 i think. question is can i keep the 3.23's from my car in conjunction with that rearend and the manual transmission... aka swapping out for larger gears.
i have an automatic by the way
Old Jul 17, 2003 | 12:26 AM
sick94's Avatar
well i put a posi rear end from a auto on my car when my rear end died. seemed to work well for me, i've got faster take off, and no problem spining 1,2, and part of 3rd when i get on it. AJ
Old Jul 17, 2003 | 12:31 AM
kingman109's Avatar
hmmm i guess it should work...just not sure if i can change out the gears themselves
Old Jul 17, 2003 | 02:06 AM
MustangEater82's Avatar
Depends on the manual...
alot of manua;ls came with 2.73s, and some came with 3.42s.
The rear axle off a z28 will jsut bolt in if oyu want to do the entire swap and everything with brake conversion.
i did the z28 rear axle swap, worked great, and I upgraded my stock 3.23s to 3.42s.
I assume you mean to swap a 6-speed not a 5-speed, if you plan on putting a Borg Warner 5-speed thats found in v6s behind anything with any torque, you are asking for trouble.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Feb 15, 2015 08:12 AM
jb4xx
Feb 2, 2015 10:00 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
