How to get stripped Screw off?
Old Jun 15, 2003 | 11:38 PM
jtj2000's Avatar
I have two 7/32 screws that are stripped on my ignition coils. I can't get them off no matter what. How would you go about getting them off. My problem is all the coils are sparking except for one. I replaced all of them and it worked for a while and now it is doing the same thing, only sparking of 5 of the 6 sparkers. What do you think the problem is and what would you do? Thanks
Jason
Old Jun 16, 2003 | 12:29 AM
fbird95's Avatar
Screw extractor should do the trick.
Old Jun 16, 2003 | 05:08 PM
MustangEater82's Avatar
is it a screw or bolt? if I remeber most the things on coils are bolts, if bolts try a pair of vice grips, and get a new screw later.
Old Jun 16, 2003 | 08:22 PM
fbird95's Avatar
Like MustangEater said, i didnt mention that i assumed that it was a bolt, vise grips may do the trick, but they may also chew up the coil, and i'm not sure how much you care about the engine bay, but i would do it causishly either way.
Formula Steve
Sep 19, 2023 08:31 AM
Quickss96
Jan 29, 2016 05:56 PM
93 RedBird
Nov 15, 2015 08:24 AM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
