Rearend noise
Old Jul 19, 2003 | 01:23 PM
JB_96RS's Avatar
Rearend noise
Hello! I've got a sound coming for my rearend !!! LOL. It sounds like a dry gear winding down. I noticed that my pumpkin was leaking so I changed the seal/fluid. Noise is still there. Suggestions?
Old Jul 19, 2003 | 01:53 PM
nothingeined's Avatar
Possible bent rim. That is what happen to mine. It was like a creaking noise everytime I would slow down or speed up, I would hear this creaking noise. Bought a new one and no more.
Old Jul 19, 2003 | 08:01 PM
Camarobabe's Avatar
My rearend was making a grinding noise, my rear bearings were bad. Had 'em replaced, no more noise.
Old Jul 19, 2003 | 08:10 PM
To really in point if it is a bent rim, and not other stuff, borrow a rim from somebody. I was lucky that a couple of friends have some camaros so we just switched for like 10 minutes and found out it was the rim. If not check your bearings too.
Old Jul 19, 2003 | 08:39 PM
sick94's Avatar
my rear end was makin a noise too, like a howling noise, and when i took off the plate to figure out the problem, i found a wad of metal bout the size of a small baseball in there. try the rim first and if not you might want to look into a new rearend. good luck on it,
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
mrwz28
Jul 8, 2015 09:11 PM
colts0455
Jul 7, 2015 07:19 PM
