5speed gear ratios.
Old Jun 10, 2003 | 06:54 PM
downndirtys10's Avatar
5speed gear ratios.
I am looking at installing a camaro 5speed behind this 3.4l that I installed in my truck. I am needing a bit of help on which one I should install. Resources have told me that the 3rdgen 5speed is different then the 4th gen 5speed.
First question, what is the gearing for both?? 3rd and 4th gen.
Second, does the 4thgen have a removable bell housing??
So far, I know the 3rdgen 5sp has removable bellhousing, which would make easier to adapt to my slave cylinder.
As for gearing, all I can find is...
3rdgen
1. ?
2. ?
3. ?
4. ?
5. .63
4thgen
1. 3.75
2. ?
3. ?
4. ?
5. .76
Old Jun 10, 2003 | 08:14 PM
BadLiLBowtie's Avatar
hmm.. I wana know that too... also what is the 5 speed 3.4 tranny code (i.e. T-56 = 6 Speed in 1994 Z28 and other Z's) or is it just called a M5?
Old Jun 10, 2003 | 09:35 PM
rpo is m49, but its still a t5, just like before, from atleast 85 to 95, its called t5.
Old Jun 11, 2003 | 11:48 AM
Wolfie's Avatar
4th gen ratios:
1st 3.75
2nd 2.19
3rd 1.41
4th 1.00
5th 0.74
also, the 4th gens t-5 has a 26 spline input shaft(like the v8's) while the 3rd gens have a 14 spline input shat, bouth bellhousings are removable
Old Jun 11, 2003 | 12:28 PM
oo wow, didn't know that about the splines. Much thanks for that!!! That would be why they are non-interchangeable.
Although that throws the 4thgen t5 in the trash
Old Jun 11, 2003 | 05:10 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
Transmission Gear Ratios
1 2 3 4 5 6
T56 3.36 2.07 1.35 1.00 0.80 0.62 93 Only
T56 2.66 1.78 1.30 1.00 0.74 0.50 94 and later
T5 2.95 1.94 1.34 1.00 0.74
4L60E 3.06 1.63 1.00 0.70
Old Jun 16, 2003 | 03:13 PM
IndyTruck's Avatar
The T5 ratios atl2001 listed look like 3rd gen v8 ratios. The 3rd gen v6, from what I can find, had a ~4:1 first and a huge gap to 2nd and a .67 5th.
atl, can you say for sure what those ratios are from? If they're 4th gen V6 I think that'd be very interesting....
I admit I'm just repeating what I've seen elsewhere, but it seems like it may be correct.
But any sure firsthand info is very welcome.
thanks
kevin
Old Jun 16, 2003 | 03:18 PM
High Indy, you do know me from elsewhere. I'm the one buying some parts off you. Hint Hint.
Old Jun 16, 2003 | 03:24 PM
IndyTruck's Avatar
LOL! Dr Livingston, I presume?
Old Jun 16, 2003 | 09:03 PM
Nope, "Dale"
Old Jun 16, 2003 | 09:47 PM
IndyTruck's Avatar
Aare you messing with me or are you too young to remember that movie line? "Dr Livingston, I presume?"
They even used it in the Flintstones, except it was "Dr Livingstone, I presume?"
I knew it was you Dale!
Now get to work finding those ratios!
kevin
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
CARiD
Apr 8, 2015 08:08 AM
ithacamike
13
Sep 15, 2002 05:55 PM
guionM
39
Sep 3, 2002 09:16 PM
