ABS/brake problems
Old Jul 8, 2003 | 09:39 AM
CMJ917-95CMO's Avatar
Exclamation ABS/brake problems
I've recently had some serious trouble with my brakes. Last time I got the codes pulled, I had a passenger-side front wheel speed sensor error code, but my ABS still worked fine. Now, under normal braking, my low trac indicator will light, and after this occurs a few times, I will lose brake pressure for a split second and the ABS Inop indicator will come on. Last time I was quoted for a wheel speed sensor replacement, it was rather expensive. If this is the problem, can I fix it myself? Has anyone else had this problem or something similar? Thanks for the help.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
