Muffler Size?
Old Jun 1, 2003 | 09:28 AM
nothingeined's Avatar
Question Muffler Size?
Will a stock muffler from a 95-97 v6 muffler fit a 2000 camaro v6? Thanks!
Old Jun 1, 2003 | 04:46 PM
fbird95's Avatar
Fit right on. Not sure about that. If i remember correctly they are the same length and both have the same inlet of 2.25".
However, I can tell you that they use different hangers on the left side. The 93-97 mufflers on 6 cyl use a hanger specific to the 6 cyl, where as the 98+ 6 cyl use the same hanger and insulator as the 8 cyl
p/n 10243316 for the Insulator
p/n 10407350 for the Hanger
Old Jun 1, 2003 | 04:48 PM
Cool! Would a normal muffler shop keep items like that in stock? Or would I have to stop by the dealership to pick some up? Thanks for the help!
Old Jun 1, 2003 | 05:51 PM
fbird95's Avatar
A muffler shop could most likely sell you different hangers. But i would personally go to the dealership and get them. They run about 11-20 bucks for both depending on whether they charge you the shop fee (their cost) or the List price (to make a profit) They bolt right up with the two existing bolts to bottom of the frame. Its also is a good idea to gets these, in case you later decide you want to bolt on a take off muffler from an 8cyl. then it just about bolts right up with some modification to the reducer on the 8 cyl muffler. Hope that helps you out.
Old Jun 1, 2003 | 05:54 PM
Thank you very much. Helped out plenty
Old Jun 3, 2003 | 11:35 PM
idlerecords's Avatar
so if I am putting in the z28 muffler from 2000 into a 1995 V6, I need to get new hangers? I dont know what hangers are, I am figuring they are what keeps the exhaut up.
Old Jun 4, 2003 | 01:08 AM
fbird95's Avatar
i listed the hanger and Insulator part number above
they are both for the 98+ cars
You will also need a reducer if you plan to bolt it up
If your gonna install it, let me know and i'll give you the run down
I've done two of them so far
Old Jun 4, 2003 | 01:13 AM
fbird95's Avatar
Probably would be easiest if you IM me at Slash3434
Quickss96
Jan 29, 2016 05:56 PM
Queens94z28
Sep 20, 2015 08:45 PM
RX Speed Works
Aug 20, 2015 03:40 PM
Dams76
Aug 20, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
