A4 sliping? Need help A.S.A.P.
Old May 30, 2003 | 04:56 PM
WhiteKnight98's Avatar
Ok, up until just about 30min. ago I have not had no problems that would indicate this. When I take off from a light or a stop, I can not accelerate worth a damn. It's acting as if the trans is not catching. It revs up, but no go. I checked all my fluids and everything seems to be fine. This happens around 2,000 - 2,500rpms. And then it might catch. The check engine light started flashing and then stayed on. What is going on?
Old May 30, 2003 | 05:07 PM
All_InTheRED's Avatar
With a code being set....that should direct you to where the problem is.
More than likely the code is for a "excessive slippage" ( as if like we didn't allready know that).
Get the code read.
Old May 30, 2003 | 06:25 PM
Thanks, figured it all out. It's cool now.
DarkKnight
Oct 5, 2010 05:35 PM
mrbadlt1
Jun 22, 2010 01:04 PM
kline454
May 2, 2007 02:15 AM
xxsaint69x
Jun 14, 2004 09:41 AM
thzzz28man
Sep 7, 2003 11:41 AM
