Anyone have a stock 3.42 A4 Tunercat BIN file?
Old Sep 2, 2003 | 11:23 PM
xchief1320's Avatar
I am wanting to check something..
Steve
xchief1320@aol.com
Old Sep 2, 2003 | 11:30 PM
Dan K's Avatar
If you mean stock stock, there is no such thing.
Unless you want a stock A4 file that is just set up for a 3.42?
Cause technically what you're looking for doesn't exist as far as I know.
Old Sep 2, 2003 | 11:33 PM
EviLZ28's Avatar
I have a file out of a 94 with an A4 and a 3.23
If that helps any
Old Sep 2, 2003 | 11:34 PM
xchief1320's Avatar
yes i want a stock A4 file setup for 3.42's..I am wondering what all needs to be changed other then just putting in the gear ratio..
Steve
Old Sep 2, 2003 | 11:36 PM
xchief1320's Avatar
Can you send it as well?so i can compare it..I have a 2.73 A4 file but nothing else..
Steve
xchief1320@aol.com
Old Sep 2, 2003 | 11:38 PM
Dan K's Avatar
I think LT1 Edit automatically sets up all of the trans tables that are based off of mph when you change the gear ratio.
Pretty sure no version of Tunercat does.
All you'd need to do is go into all of the trans tables that have mph references and multiply them by old gear ratio/new gear ratio.
So if you switch from 2.73 to 3.42 multiply by .798.
Hope this helps.
Old Sep 2, 2003 | 11:53 PM
madwolf's Avatar
Whatever you do, just make sure you get a file for your year. A 94 file won't work in a 95 car and vice versa due to differences in the A4 transmission.
And Dan was right, there was no stock A4 3.42 available.
Old Sep 2, 2003 | 11:59 PM
xchief1320's Avatar
Yeah i figured as much about the completely stock A4 3.42 file..I was hoping someone had modified one and had good luck with it so i could see what percent the difference was.And with Dan telling me the percent it answers the question without all the work..lol..
Steve
Old Sep 3, 2003 | 12:00 AM
madwolf's Avatar
If you still don't have it, just tell me what year you need it for and I'll email you a modified one.
Old Sep 3, 2003 | 12:04 AM
xchief1320's Avatar
94 A4 Formula
Dan sent me a 95 file.but as you mentioned it won't work will it?
On a different note..what definition file do i need to use? i been using the $EE one with no prolems..But Dan mentioned the 94's use the EEB..when i click on the EEB file and click the the constant tab all the #'s are way off..But when i use $EE they are correct..
Sorry for the stupid questions.Just started Tunercat 2 days ago..
Steve
Old Sep 3, 2003 | 12:05 AM
Dan K's Avatar
Ah, but can't he import the shift point tables and torque converter lock/unlock tables from EE to EEB?
Or no?
What year did you need it for anyways Steve?
Old Sep 3, 2003 | 12:06 AM
xchief1320's Avatar
All this info is for my 94 A4 Formula..It has 2.73's in it now but i am putting 3.42's in it tomorrow
Steve
Old Sep 3, 2003 | 12:08 AM
EviLZ28's Avatar
So the bin I sent ya should be pretty close since your goin to 3.42's and the bin has 3.23's stock.
Old Sep 3, 2003 | 12:10 AM
Dan K's Avatar
Since Ion is offering his services...take him up on it.
xchief1320's Avatar
yeah tru..and it was for a 94 also correct..I can just do the math on the tables myself to make sure it is dead on..but that one will prolly get me real close..
Steve
