Anybody know if my injectors are maxed out?
Old Aug 11, 2003 | 10:38 PM
jmzlt1's Avatar
I did a full throttle run with my scanmaster the other day. I got an injector pulse at 11.0 on the scanmaster. Anybody know what percentage this works out to be regarding the duty cycle of my injectors? I currently have 24lb svo injectors. Thanks in advance.
Old Aug 11, 2003 | 11:47 PM
turbo_Z's Avatar
with that kinda power i say you are really close to maxing them out if they arent.
Old Aug 12, 2003 | 01:21 AM
BPS's Avatar
BPS
I've seen a pulse width in the high 14 range so you still have a way to go
Old Aug 12, 2003 | 10:38 AM
Duty cycle is your pulse width, divided by the time available in two crank revolutions, so you need to know an RPM along with the pulse width to determine if the injector is being max'd out (greater than 90% duty cycle).
At 6,000RPM the time available in two crank revs is 20mS. So if you see an 18mS pulse width at 6,000RPM, your duty cycle is:
18 / 20 = 0.90 = 90%.
An 11mS pulse width doesn't even come close to maxing things out unless you are seeing it at 7,500RPM.
As a guideline, maximum possible pulse width vs. RPM:
5,000rpm - 24.0mS (80%DC = 19.2mS)
5,500rpm - 21.8mS (80%DC = 17,5mS)
6,000rpm - 20.0mS (80%DC = 16.0mS)
6,500rpm - 18.4mS (80%DC = 14.7mS)
7,000rpm - 17.1mS (80%DC = 13.7mS)
7,500rpm - 16.0mS (80%DC = 12.8mS)
Old Aug 12, 2003 | 02:40 PM
turbo_Z's Avatar
man, my 30lbs SVOs must be way overkill for me then with the 224/230 and stock heads... thanks for the guideline Fred!
Old Aug 12, 2003 | 09:50 PM
jmzlt1's Avatar
Thanks Injuneer. Strange, I got that reading at about 6000 rpm. Maybe I should check it out again, something doesn't sound right. Thanks. Do you race at englishtown Injuneer? I don't think I've seen you there.
Old Aug 14, 2003 | 02:55 PM
ZPaul2Fresh8's Avatar
I thought SVOs were rated differently than stock injectors? If so then if what I'm thinking is correct then you swapped to smaller injectors since the stockers are 24#s themselves... No?
Old Aug 14, 2003 | 08:19 PM
jmzlt1's Avatar
Ford rates their injectors at 35 psi. when installed on an lt1, with stock fuel pressure 43.5, they end up putting out a bit more. About 26 or so.
Old Sep 13, 2003 | 08:58 AM
jmzlt1's Avatar
I checked my duty cycle again. I still got an 11.5 on my scanmaster for the left bank at 6000 rpm. This doesn't make any sense, that means I'm only getting a 58% duty cycle at 6000 rpm? Something isn't right, anybody have any thoughts? Thanks in advance.
Old Sep 13, 2003 | 01:01 PM
Just a thought, but did you ever get a tune for those bigger injectors?
Old Sep 13, 2003 | 09:53 PM
jmzlt1's Avatar
Yep, Bryan did the tune. I only gained 1 pound of torque over the hypertech, which are the numbers I have in the sig. I got the last injector reading with his program.
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
