Shift tables 95 a4 3.23
Old Sep 4, 2003 | 02:13 PM
djc485's Avatar
Unhappy Shift tables 95 a4 3.23
I recently had my car hooked up to a tuner cat to fix my speedometer. It turns out the gear setting was calibrated for a car with 2.73. After I changed the gears the shift tables were deleted and I had to estimate the shift points. I am pretty close but exact I hit the rev limiter if I give it to much gas to close to the redline. I am looking for the shift tables for a 95 a4 with 3.23's any response would be greatly appreciated.
Old Sep 4, 2003 | 08:05 PM
Hotwire's Avatar
i have my stock lt1 file,
wot shift table:
1-2 36mph
2-3 73 mph
3-4 126 mph
hope this helps
Old Sep 4, 2003 | 10:04 PM
djc485's Avatar
Thank you, do you possibly have the downshift points, or maybe the whole table? Thanks again!
Old Sep 5, 2003 | 01:03 AM
xchief1320's Avatar
What about adding a stock BIN to the tuner so you can compare?
I have a stock 94 A4 323 Bin if that would help..It's not a 95 though.So i'm not sure if it will work..If you post your e-mail i'll be glad to send you the 94 BIN i have..
On my table it says WOT would be
upshift
1-2..36
2-3..73
3-4..126
downshift
2-1..31
3-2..67
4-3..118
Steve
Old Sep 5, 2003 | 02:09 PM
djc485's Avatar
That would be a great refrence for me. If you could email it to djc485@cs.com when you get a chance I would be very greatful!
Old Sep 5, 2003 | 02:10 PM
xchief1320's Avatar
You got mail...
Steve
Old Sep 5, 2003 | 03:18 PM
Just posted in another thread, but here is a 1995 A4 3.23 bin file.
Old Sep 7, 2003 | 11:44 AM
djc485's Avatar
Question
I can not open either of those files. Do I need some type of special software?
Old Sep 7, 2003 | 12:16 PM
xchief1320's Avatar
Are you saving them in your Tunercat folder?if not then it won't open them..
If your home PC "or whichever one you're online with" isn't the one with Tunercat on it you will need to save the BIN file on a 3 1/2" floppy or CD and then use that to save it on your laptop that has Tunercat on it..
I didn't have any trouble with the one shoebox posted..
Steve
Old Sep 7, 2003 | 06:32 PM
djc485's Avatar
thank you ill do that
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
