No serial port on the laptop... USB?
Old Aug 30, 2003 | 12:21 PM
xxsaint69x's Avatar
Hey guys, i got a laptop but it doesnt have the Serial Port. I bought a USB to serial cable adapter. When i tired connecting to the pcm it wouldnt sync up..any ideas why ?
btw i was using DataMaster.
HAs anyone get it to work like that before?
Marcin
Old Aug 30, 2003 | 05:39 PM
jkipp84's Avatar
I had the same problem. First I tried the adapter from Radio Shack and had no luck. I returned that and got the Belkin F5U103 adapter at Best Buy and that did the trick. It was about $60 though.
Old Aug 30, 2003 | 05:42 PM
xxsaint69x's Avatar
damn, i got one of those from ebay for 4 bucks http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EOT:US:3
Does it also work with LT1 edit?
Old Aug 30, 2003 | 05:51 PM
jkipp84's Avatar
If you can get it to connect, it should work regardless the software. Emphasis on should . I've only used it with Freescan so far and connect every time with no problems.. got my tuning from Bryan, btw.
Old Aug 30, 2003 | 05:54 PM
xxsaint69x's Avatar
I downloaded the ADAL test from Datamaster Site and it works fine. I but i cant get it to connect to the damn PCM!
Anything i can do to make it work?
Old Aug 30, 2003 | 05:57 PM
jkipp84's Avatar
Sorry, I meant the Belkin. I ran all those tests too, the laptop and Radio Shack adapter were fine, the problem is between the adapter and the pcm. GM has some funky baud rate that the adapter didn't work with. The Belkin does fine with it though.
Old Aug 30, 2003 | 09:46 PM
RCF925's Avatar
Had the same problem, Belkin fixed it
Old Aug 30, 2003 | 11:28 PM
xxsaint69x's Avatar
whats the part number for the belkin that works?
Old Sep 2, 2003 | 02:17 PM
See post at top from jkipp84.
AutoTap also recommends:
Q. Do you have a USB version of the AutoTap OBD II scan tool?
A. No, but you can use our USB adapter to add a serial port to your laptop or PC. We have tested AutoTap with B&B Electronics models UC232A and Edgeport/1 available here.
You can also check with Andrew at AKM Cables. He had some "refurbished" Belkins at a discount a while back.
Old Sep 2, 2003 | 08:46 PM
arnie's Avatar
Bought a Gateway laptop for programing that didn't have a serial port. Sold the laptop, so I no longer need the new Belkin F5U103.
Old Nov 6, 2003 | 02:53 PM
Highlander's Avatar
PCMCIA Serial.. many on ebay
Old Nov 14, 2003 | 11:46 AM
Bodenham's Avatar
I went thru the same disaster trying adaptors for USB-serial, PCMCIA-serial, one from Radio shak, a belkin PCMCIA adaptor, another off brand from Best Buy. NONE WORKED!! total PITA. ditch the laptop and get one with a factory serial port. sounds extreme, but if it doesn't work....
Old Nov 14, 2003 | 02:15 PM
xxsaint69x's Avatar
i have the belkin adapter and it works fine. ITs all about how you install the drivers and on which com port
Old Nov 14, 2003 | 02:21 PM
Highlander's Avatar
I have bought 7 different PCMCIA-serial... ALL WORKED PERFECTLY.. no hitch.. fast....
USBs have some kind of delay in them...
Old Nov 14, 2003 | 06:42 PM
Bodenham's Avatar
my problem was communicating with the PCM using LT1 edit. I went thru all the com port matching between edit and the device, deleted other drivers not in use, downloaded the newest drivers, ect. Compaq has a very inexpensive unit new for $700 with the serial port. Don't buy a new dell assuming that a $40 adaptor will get you going. I've read of many others who have had similar bad experiences, some say their's worked great first try. My advice is to shop wisely for new or used laptops if you are going to be using Edit, get one with a serial port.
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
