Someone help!! Starts up but turns off in 1 sec
Old Sep 14, 2003 | 04:23 AM
LT1RX7's Avatar
I just started up the LT1 engine in my RX7 but I'm having an issue. The engine starts up but only stays on for about a sec then turns off. Even when I have the throttle 1/2 open it'll idle high then turn off. I'm thinking it's a computer problem seeing how it just turns off no matter what throttle I give it. I don't have the O2 sensors in yet but I think it should still idle. Would an LT1edit tel me the prob?
Old Sep 14, 2003 | 04:27 AM
madwolf's Avatar
Did you disable VATS?
Old Sep 14, 2003 | 12:15 PM
MAF connected?
Old Sep 14, 2003 | 01:48 PM
LT1RX7's Avatar
MAF is connected and VATS was deleted from PCM
Old Sep 15, 2003 | 11:00 PM
TriPinTaZ's Avatar
is your MAP sensor installed?
Old Sep 16, 2003 | 12:40 AM
LT1RX7's Avatar
it is installed but wheather it's working or not is a different story. My freind had a map sensor go out but it still ran, just like crap
Old Sep 16, 2003 | 02:10 AM
rskrause's Avatar
Moderator
Codes?
A big vacuum leak will do this.
Rich Krause
Old Sep 16, 2003 | 04:32 AM
LT1RX7's Avatar
how about that big rubber thing that a pipe is suppose to stick into? It's on the driver side that I think goes to the valve covers. Could that cause a vacuum leak? Mine is not plugged
Old Sep 16, 2003 | 04:48 AM
LT1RX7's Avatar
OK, I found that and the low oil sensor was broken completly off. Could the PCM be sensine no oil pressure and turn the engine off?
Old Sep 16, 2003 | 05:11 PM
It could if there was a wire going from the sensor to the pcm, but there isn't. The only wire coming from the oil pressure sensor goes to the gauge.
Old Sep 16, 2003 | 06:55 PM
turbo_Z's Avatar
when you turn the key to the on position just so you have power from the battery, does the SES light flash or do your fans turn on?
Old Sep 16, 2003 | 10:59 PM
LT1RX7's Avatar
the SES light goes on but does not flash. I found that the hole in the intake is for the PCV or something
Old Sep 23, 2003 | 03:54 PM
chevysam's Avatar
Are you using a Camaro or Corvette computer?
I just did a swap using a Vette computer and I'm having the same problem. I have used Camaro computers with no problem. The VATS system ties into the Vette PCM in a different way.
DirtyDaveW
Dec 1, 2016 05:37 PM
Scottyboy
Feb 11, 2015 10:28 PM
warmeck
Feb 5, 2015 11:04 AM
Dave19yz28
Jan 26, 2003 01:45 PM
formula79
26
Aug 5, 2002 12:21 PM
