Tuning tips?!? Help me out allittle here!
Old Aug 25, 2003 | 10:42 PM
LT1hero93's Avatar
Question Tuning tips?!? Help me out allittle here!
I just got every thang to tune my car but I have a few questions! First what kinda chip does the factory use? I mean the exact factory equipment. 1993 z28. I need to know this because I wana copy the factory chip to my pc , but the program has differant voltages for each differant chip and if i don't select the right chip I will fry my stock chip and have nothin to work with!
Also once I get the bin copyed can I just put the new bin on a AT29C256 chip with no "SPECIAL" programing and plug it right up to my car and go!?
Now for the tuning stuff. What are some thangs I can change to get allittle more performance? I have no clue what any thang does in tunercat and I don't wana blow the engine. So what are some basic thangs I can change to get alittle more power?
Thanks for the help
Shawn
Old Aug 25, 2003 | 10:48 PM
Dan K's Avatar
Check right on the chip, it might tell you what voltage to program it at. Actually it doesn't matter, I don't think it matters since you aren't programming it...just reading it.
Old Aug 27, 2003 | 04:47 PM
LT1hero93's Avatar
My extended spark and spark table is stock where in it can I add a few degrees and how many degrees can I add? I wana make some more power If any one can help me tune allittle I would appreciate it!
Shawn
Old Aug 27, 2003 | 10:46 PM
Dan K's Avatar
That's something you're going to have to screw around with a little. On a stock car the stock programming is actually quite aggressive. In most cases, it actually has too much timing. I would set it up so that you get 36-38* at wot.
Part throttle stuff is also something you're going to have to experiment with. I would start out by adding 1 or 2 degrees in the rpm and map range that you're driving in under most conditions and see what effect that has on the car. Butt-o-meter is about all you'll be able to use to tell though. You might feel that the car just feels "smoother"...not sure how else to describe it.
2QUIK6
Jul 15, 2015 07:46 PM
mrwz28
Jul 8, 2015 09:11 PM
pimpen1024
Jul 8, 2015 09:08 PM
May 15, 2015 10:43 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
