Ltrem fuel maxed out @ +25
Old Aug 24, 2003 | 06:26 AM
Schurters LT1's Avatar
My Ltrem fuel is maxed @ +25 and the Strem is @ +14 at idle, how do i bring this down.
I have tuner cat ,
-adj inj constant up to 31.60 (i have 30 lbs svo)
-idle up to 900rpm
-24* timming (should i add more at idle)
need all the help i can get thx
Old Aug 25, 2003 | 01:06 AM
Dan K's Avatar
You can screw with injector constant a little if you want. If you raise it a little you will lower the pulsewidth at all rpm. If you can find the sweet spot on the injector constant, it will require less fiddling with the maf tables if you're going to try and get your blm's to a certain area. I shoot for 118-138 and if they're in there it's good enough for me. As long as the ECM is making its corrections you should be ok.
95chwagon
May 27, 2015 09:53 AM
alex5366
Feb 17, 2015 09:07 AM
Burn_Out
Aug 18, 2002 08:49 AM
944LT1
Jun 24, 2002 10:36 PM
