Random multiple DTCs?
Old Aug 10, 2003 | 12:23 PM
96speed's Avatar
Every 3-4 months I seem to throw several codes. Normally I get both high/low opti codes along with a couple other random codes. Last night it happened to be the Injector Circuit and EE Prom Error codes.
I will be starting the car, it catches, and then it just dies. Crank it for a couple seconds and it starts up showing all the codes, and to top it off the A/C stopped working.
I drove around for a bit, and then I stopped and pulled the pcm fuse (reset the codes). Started it back up, and the car ran perfect.
Anyone else experience this "hiccup". Not sure what to call it...
Ryan
Old Aug 10, 2003 | 10:18 PM
Central PA Z's Avatar
I had this same problem one night. It was the first night I tried my new changes I got from PCMFORLESS. I tried my usual long stright road in the country and mashed it. I got 6 different DTC at that point. Car ran like a 2 cycle dirt bike with a fouled plug. I stopped and pulled the PCM fuse and all was fine after that. I contacted Bryan and told him what happened. He deturmined by the odd codes I was getting, (I believe they were 51, 88, 90, 91 and I can't remember the other two) that it was just a bad flash. Sure enough, I re-flashed w/ the same program and all has been well since. If you have the ability to re-flash your PCM, do try it, as I am sure it will work.
~John
Old Aug 11, 2003 | 10:27 AM
96speed's Avatar
John - Very interesting. I will try a reflash.
thanks,
Ryan
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
KYWes
Sep 26, 2015 08:49 AM
greenzee28
Sep 25, 2015 04:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
