Bad PCM?
Old Aug 13, 2003 | 11:24 PM
fireman's Avatar
Bad PCM?
My tuner told me my PCM "locked" up a while back. I bought a used one, plugged it in, and tried to start it. Fired up then died, over and over.
At first I thought it was just cold, nope. I tried to give it gas as soon as it fired, it was as if my throttle was not even there.
The fans came on as soon as I turned the key on and didn't turn off.
I hooked up a Snap On scanner, the kind with a big readout and tells you exactly what to do. Could not communicate with PCM. I hook up the ol' Scanmaster, it powers up when I turn the key and thats it.
any ideas?
Old Aug 15, 2003 | 11:00 AM
fireman's Avatar
ttt
Old Aug 16, 2003 | 12:33 AM
tjwong's Avatar
It sounds like a VATS problem. However one thing you can try is to have it flashed with the correct calibration for your VIN. If you have a means of programming it I can send you a calibration for your VIN. Just send me your VIN and I can email a calibration to you. The other way is to take it to a GM dealership and have them flash it.
Old Aug 17, 2003 | 12:22 AM
fireman's Avatar
Thanks, I appreciate the offer. I have since sent that PCM back.
I'm waiting for my original PCM to come back(fixed) from AKM. If I have problems with that one, I may need a file.
TitoPR221
May 26, 2015 12:20 AM
Zuvell
May 15, 2015 08:18 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
