Looking for a code listing
Old Aug 17, 2003 | 01:07 PM
Dave Feerst's Avatar
Does anyone have a list of all of the codes and their definitions?
I mainly want the list for my 94 but if you have other years too I'd like those too so I can help friends....
Old Aug 17, 2003 | 01:17 PM
Dan K's Avatar
I'm e-mailing it now.
edit: no I'm not, your e-mail doesn't work
94-95 OBD I LT1 DTCs
DTC 11 - Malfunction Indicator Lamp (MIL) Circuit
DTC 13 - Bank I (Left) Heated Oxygen Sensor (HO2S) Circuit (Open Circuit)
DTC 14 - Engine Coolant Temperature (ECT) Sensor Circuit ( Voltage Low, High Temp)
DTC 15 - Engine Coolant Temperature (ECT) Sensor Circuit ( Voltage High, Low Temp)
DTC 16 - Distributor Ignition System (Low Resolution Pulse)
DTC 18 - Injector Circuit(s)
DTC 21 - Throttle Position (TP) Sensor Circuit (Signal Voltage High)
DTC 22 - Throttle Position (TP) Sensor Circuit (Signal Voltage Low)
DTC 23 - Intake Air Temperature (IAT) Sensor Circuit ( Voltage High, Low Temp)
DTC 24 - Vehicle Speed Sensor (VSS) Circuit
DTC 25 - Intake Air Temperature (IAT) Sensor Circuit ( Voltage Low, High Temp)
DTC 26 - Evaporative Emission (EVAP) Canister Purge Solenoid Valve Circuit
DTC 27 - Exhaust Gas Recirculation (EGR) Vacuum Control Signal Solenoid Valve Circuit
DTC 28 - Transmission Range (TR) Pressure Switch Assembly Fault
DTC 29 - Secondary Air Injection (AIR) Pump Circuit
DTC 32 - Exhaust Gas Recirculation (EGR)
DTC 33 - Manifold Absolute Pressure (MAP) Sensor Circuit ( Voltage High - Low Vacuum)
DTC 34 - Manifold Absolute Pressure (MAP) Sensor Circuit ( Voltage Low - High Vacuum)
DTC 36 - Distributor Ignition System (Faulty High Res. or Extra Low Res. Pulse Detected)
DTC 37 - Brake Switch Stuck "ON
DTC 38 - Brake Switch Stuck "OFF
DTC 41 - Ignition Control (IC) Circuit (Open Circuit)
DTC 42 - Ignition Control (IC) Circuit (Shorted or Grounded Circuit)
DTC 43 - Knock Sensor (KS) Circuit
DTC 44 - Bank 1 (Left) Heated Oxygen Sensor (HO2S) Circuit (Lean Exhaust Indicated)
DTC 45 - Bank 1 (Left) Heated Oxygen.Sensor (HO2S) Circuit (Rich Exhaust Indicated)
DTC 46 - PASS-Key Circuit
DTC 47 - Knock Sensor (KS) Circuit or Module Missing
DTC 48 - Mass Air Flow (MAF) Sensor Circuit
DTC 50 - System Voltage Low
DTC 51 - EEPROM Programming Error
DTC 53 - System Voltage High
DTC 55 - Fuel Lean Monitor
DTC 58 - Transmission Fluid Temperature (TFT) Sensor Circuit Low (High Temp )
DTC 59 - Transmission Fluid Temperature (Low Temperature Indicated)
DTC 61 - A/C System Performance
DTC 63 - Bank 2 (Right) Heated Oxygen Sensor (HO2S) Circuit (Open Circuit)
DTC 64 - Bank 2 (Right) Heated Oxygen Sensor (HO2S) Circuit (Lean Exhaust Indicated)
DTC 65 - Bank 2 (Right) Heated Oxygen Sensor (HO2S) Circuit (Rich Exhaust Indicated)
DTC 66 - A/C Refrigerant Pressure Sensor Circuit (Open or Shorted)
DTC 67 - A/C Refrigerant Pressure Sensor Circuit (Pressure Sensor Activity)
DTC 68 - A/C Relay Circuit (Shorted Circuit)
DTC 69 - A/C Clutch Circuit
DTC 70 - A/C Clutch Relay Driver Circuit
DTC 71 - A/C Evaporator Temperature Sensor Circuit
DTC 72 - Vehicle Speed Sensor Loss
DTC 73 - Pressure Control Solenoid (PCS) Circuit (Current Error)
DTC 74 - Traction Control System(TCS)CircuitLow
DTC 75 - Transmission System Voltage Low
DTC 77 - Cooling Fan Relay Control Circuit
DTC 78 - Fan control PCM terminal A10
DTC 79 - Transmission Fluid Overtemp
DTC 80 - Transmission Component slipping
DTC 81 - Transmission 2- 3 Shift Solenoid Circuit
DTC 82 - Transmission 1-2 Shift Solenoid Circuit
DTC 83 - Reverse Inhibit System (Manual Transmission) <<<<<<<<<select>>>>>>
DTC 83 - TCC/PWM (Auto Trans)
DTC 84 - Automatic Transmission 3-2 Control Solenoid Circuit <<<select>>>>>>
DTC 84 - Skip Shift Solenoid Circuit (Manual Transmission Only)
DTC 85 - Transmission TCC Stuck "ON
DTC 90 - Transmission TCC Solenoid Circuit
DTC 91 - Skip Shift Lamp Circuit
DTC 97 - VSS Output Circuit
DTC 99 - Tach Output Circuit
Old Aug 17, 2003 | 02:44 PM
thanks a ton.
Jan 23, 2015 01:13 PM
Dec 5, 2014 11:42 AM
Dec 1, 2014 08:08 AM
91Bird305
Aug 5, 2002 01:39 PM
