P0102 Mass Or Volume Air Flow Circuit Low Input
Old Sep 15, 2003 | 06:00 PM
99SSBILL's Avatar
I GET THE P0102 VOLUME AIR FLOW CIRCUIT LOW INPUT CODE. I REPLACED THE MAF AND THE CODE STILL COMES BACK EVERY TIME I CLEAR IT. ANY SUGESTIONS?
Old Sep 15, 2003 | 06:56 PM
ss rally red's Avatar
Try cleaning your maf wires they can sometimes get dirty and throw that code its common if you run a Holly,K & N etc.
Old Sep 15, 2003 | 10:58 PM
TriPinTaZ's Avatar
He replaced the MAF so cleaning it would be useless.
Are you sure you have no leaks in the intake after the MAF? If not your problem is not your MAF, you need to look elsewhere
Old Sep 23, 2003 | 07:30 PM
99SSBILL's Avatar
Wink
Found the problem. The hot wire for the maf circuit also feeds the heated oxygen sensor and it got up against the header causing the short. Thanks for your help.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Fatdog2
Feb 13, 2015 08:19 PM
95chwagon
Jan 13, 2015 09:19 PM
