how to set up idle tuner cat
i went to the ecm constant table and change my inj to 30lbs(inj flow rate)
how do i adjust idle from 800rpm to 900rpm and up more with A/C
i can,t find idle adj
i have read that you have to adj the maf by 20 % so i went from 2.40 gm/sec to 280 @ 1488hz i add 20% up to 2000hz do i have to do the hole thing ? p&p maf
i add 2* timing all the way up to 7000rpm
where to you adj fuel + -
i have no pe table?
i have data master and i max out my lterm +25 ?
is there anything i sould do or not do to get the idle up and lterm down.
the car start and drive fine
F/P is at 49 vac on 30 lbs svo
heads advanced ind cam gm847 all the outher stuff i would like to have the idle and driveablity set up this week then take it to the dyno.
i need all the help
THX
i have no pe table?
i need all the help
THX
So i used iac target rpm vs. coolant temp. in drive i went from 800 rpm to 875rpm all so in iac target rpm vs. coolant in park/drive.
my car is a m6
so this is my idle,
what about my inj is that right
maf sould i adjust it all the way up the rpm
were is my pe table or where do i adjust fuel.
thx
my car is a m6
so this is my idle,
thx
Re: how to set up idle tuner cat
If you have an adjustable regulator, set your fuel pressure as close to 43.5psi (with the vacuum line disconnected) as you can and try the 31.6 to start.
Your closed loop fueling is based off of injector constant and maf tables. Once you have the injector constant set correctly for your car, you can use the maf tables to nail your blms to wherever you want. I think that as long as they are between 118 and 138 that there isn't much point in screwing with it, unless you want to. Remember, the as long as the blms aren't pegged at 108 or 160 then the computer is making its fueling adjustments based on O2 sensor feedback.
i have no pe table?
When you change those injectors, make darn sure you change your "injector vs battery voltage" also.
There is a table on this site that has this information.
If you don't, you'll be running pig rich around 5500rpms and the car will slow down. Ask me how I know.
D Moss
D Moss
Dec 1, 2014 08:08 AM
