how much to alter MAF tables by for descreened MAF?
At least you understand you will have to modify your MAF tables because of the descreening.
How much will depend upon the car. mine varies from 12% taken out in the low end to 7% added on the upper end. Inbetween, a no variance area was present.
Ben
Ben
Originally posted by therealmagyver
I wanted to port the maf but not descreen, but that doesn't seem to be possible after I opened up the units. If I descreened I would need to tune?
Ben
tommalcolm
Sep 11, 2015 03:39 PM
That honey comb screen is designed to spread the incoming turbulant air more equally across the sensor, thus giving a more accurate reading of the incoming air.
