adjusting A/F ratio with Tunercat?
Old Feb 18, 2006 | 08:43 PM
MTBeni's Avatar
Ive been learning little by little how to tune my car. Ive done some reading but cant seem to find which table to adjust to move the BLM up and down to get 128. In Tunercat, Im looking at the histogram function to see where Im lean. Is this where you guys look to see what needs adjusting? There are a few Tables dealing with MAF values at the end of the table list, but I dont think thats what I need. Can someone point me in the right direction? Thanks
Old Feb 19, 2006 | 01:46 PM
turbo_Z's Avatar
Re: adjusting A/F ratio with Tunercat?
Injector constant and MAF table is where you make the adjustments. Injector constant will affect all BLMs(raise constant, raise BLM:lower constant, lower BLM) and the MAF is for more fine tuning since it only affects the BLM based on the MAF reading... and the affects are inversely related so opposite the injector constant.
Old Feb 19, 2006 | 04:55 PM
infinitebird's Avatar
That is what you want if the BLM is off in only a few cells. Looks at your AFGS in those cells and then adjust the MAF values accordingly. Be aware though that you can't just change only a few values by a lot. The data points have to form a relatively smooth curve or it will confuse the computer and the car will run like crap. I found this spreadsheet very helpful when tuning the MAF tables.
If BLMs are too rich or lean in all cells then you can adjust injector constant.
Old Feb 19, 2006 | 08:10 PM
MTBeni's Avatar
Thanks for the info. I have a another Q that may be related. At the 4000 point, I have the timing backed all the way off to 28deg. Any more and I get knock. Could I change the AF ratio here to richen it up a tad and possibly put more timing back in. Its even below the stock setting. I have a datalog and a tunercat file handy if someone would be willing to take a look. I got a little help doing the tune file and only tweaked the spark tables to get rid of the knock. New times in sig today. Thanks guys.
Old Feb 19, 2006 | 08:41 PM
If you're talking about 4000 at WOT, your better off using the %change A/F ratio vs. RPM at WOT table than changing the high MAF values.
If it's not at WOT, then that might be a possibility I guess, if the knock is being caused by a lean condition.
Old Feb 19, 2006 | 09:03 PM
MTBeni's Avatar
it is at WOT. I will look at the tables then. Thanks. How are you at reading logs?
Old Feb 21, 2006 | 06:56 PM
I can take a look if you want.
Old Feb 22, 2006 | 04:57 PM
MTBeni's Avatar
Appreciate it. I will get you the bin and log when I get to my other computer. Probably tommorow.
Old Feb 23, 2006 | 07:41 PM
MTBeni's Avatar
email sent
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
