idle rpm
idle rpm
when i reprogrammed my car i wanted to see what a lower idle would sound like. i set it at 875 rpm for both neutral and drive tables. (car is a 6 speed)
car idles at 950-1000 according to datamaster and shows 875 as the target rpm
why would it be idling so high? did i miss something??
mike
mike
Re: idle rpm
Is the coolant temp sensor input correct? That will affect idle speed. Is the VSS showing "0"? If it isn't, idle speed is elevated? Is the TPS showing "0%" and a closed throttle voltage less than 1.0V? Both those can elevate idle.
Is the IAC motor being commanded to close in response to the high idle? Is the IAC motor bottomed out at "0"?
Re: idle rpm
Seems odd..... the PCM should be lowering the IAC counts in order to pull the idle down to 875rpm. If the IAC counts are at 35, and the idle speed is high, should keep reducing the counts.
Is it possible you are reading the "learned IAC counts" rather than the commanded IAC counts? Your scan data will include both.
Re: idle rpm
Re: idle rpm
Originally Posted by JPSartre12
Learned IAC counts? Which does Scanmaster LT-1 read?
Originally Posted by limige
i'm using datamaster, i only remember seeing one listing for iac counts. it started at 51 and dropped down to about 35..
Re: idle rpm
now this may be related but i just installed new injectors (syty) tried 55#pressure and tuned for 34.6# injectors..
bank 1 Long terms when up to 160 and bank 2 went to 135 or so..
raised the fuel pressure to 75# and bank 2 came down to 128 but bank 1 is still 157 or something.
other than a possible intake leak what could cause this?
