Unexpected datalogs when at WOT?
Old Apr 24, 2006 | 08:21 AM
britLTSC's Avatar
I am I bit of a newbie to using Tunercat and wondering if I have messed up something. I have be adjusting the Power Enrichment tables and the MAF tables to remove fuel when at WOT as the wideband O2 logs have been around 10.5 and richer.
The adjustments I have made are improving this situation but I cannot fathom why the Autotap logs I am recording show the Target Air/Fuel ratio staying at 14.7 from .5 to 1.5 seconds after going to 100% throttle. It then shows 12.2 for the remaining time at WOT, in fact it stays at 12.2 for 20 plus seconds after the throttle is lifted and driving in a cruise. The wideband 02 logs also confirms the A/F is staying at 12.2.
The car is 96 LT1 (OBD2) with a Vortech SC. I have been trying to resolve this for the past two weeks, if anybody has any ideas I would appreciate the input. I could email an Excel log if that helped. Thanks.
Old Apr 26, 2006 | 07:49 AM
britLTSC's Avatar
Re: Unexpected datalogs when at WOT?
Anyone?
Am I experiencing a problem or is does the ECMs Power Enrichment mode have a delay?
It seems unlikely that PE is designed to do this, it makes tuning a real pain when the A/F jumps from 14.7 to 12.3 halfway through 2nd gear!
Old Apr 26, 2006 | 02:05 PM
Jon A's Avatar
All I can tell you is that with OBDI there is no delay. It's pretty much instantaneous when you mash the throttle. I scan with Datamaster. I wouldn't expect any difference with OBDII but I've never used it. I don't know how much that will help you.
Old Apr 27, 2006 | 06:06 AM
britLTSC's Avatar
Thanks Jon, does it also drop out of PE instant you get off the throttle?
I suspect OBD2 should behave in the same way although if anyone knows I am keen to hear. I am reasonably sure I have a problem, all I need to do know is work out the cause.
I think I need to go back and re-flash the car with the stock tune and see if PE mode behaves.
PopoFormula
Oct 12, 2015 04:19 PM
SEOJustin
Sep 24, 2015 04:39 PM
KYWes
21
Jun 14, 2015 05:59 PM
Nellsw88
May 27, 2015 10:27 PM
jayblev95
Jan 20, 2015 01:30 PM
