obd ?
Re: obd ?
It's OBDI. OBDII started with the '96 models. The '95 models have an OBDII connector, so a lot of people think they are OBDII. Makes them hard to scan or pull codes without the proper cable.
Re: obd ?
You will have an emissions label on the radiator cover. It should look just like the one from Shoebox's 95, and will show OBD-I, as Dave explained. The code in the upper left corner ("YHM") will be different, since your dual cats indicate you have a "CA emissions" A4:
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
