obd I obd II
Old Apr 12, 2006 | 06:27 AM
gillt1's Avatar
obd I obd II
Hi, Just purchased a 1996 z28 , what's difference between obdI and obdII, Thanks for any insight
Old Apr 12, 2006 | 08:03 AM
Re: obd I obd II
Basically, OBD-II adds a bunch of diagnostics to catch emissions problems...
-misfire detection using a crank sensor, including misfire counts by cylinder
-after-cat O2 sensors to measure if the cats are there and working
-O2 sensor response/switching test
-tests to verify AIR system is operating
-EVAP system flow/no flow detection
-MAF rationality test, frequency range check
-coolant time to closed loop
-more sensitive EGR flow verification
-idle speed test
-traction control excessive time on
-standardized nomenclature across brands
-standardized 16-pin ALDL connector
Most of the control strategies.... e.g. A/F ratio control.... are the same. Apparently some differences in the A4 shift logic that allows higher stall convertors.
Novo
Jun 14, 2016 02:58 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
