Dtc 67
Dtc 67
According to shoebox's website DTC 67 is "A/C refrigerant pressure sensor circuit (pressure sensor or A/C clutch circuit problem)." The car acts funny when I turn the a/c on or off. A few times it even seemed as though the car was about to stall when i turned the a/c on or off, although it didn't stall. Also, when i turn the A/C on it doesn't blow cold air. What might cause this to happen? Any help would be appreciated.
Re: Dtc 67
You'll need a set of manifold gauges (or a friend withAC tools). Failing that, buy a chaep refill can with the gauge on it. I have R12 tools but use the cheap gauge for R134. If it reads low, add freon and see if that helps. You may find a bad hose so be careful in how fast you add the freon - don't tip the can over to add the liquid freon. I would try this first as it will cost $10 or so for the refill.
Just a side note, without taking the car to someone with a removal machine, you can't check how much freon is in the system.
If the gauge reads in the green for pressure, you will have to see if you have a bad relay or pressure switch. However, the compressor should not turn on if the pressure switch was bad or the freon was empty.
tommalcolm
Sep 11, 2015 03:39 PM
