can an Ed Wright locked PCM be reflashed with tunercat?
Old Mar 24, 2006 | 09:59 PM
NC-LT1's Avatar
just like title says, I have a locked PCM and have all the tuning software, a tune I want to put in my PCM and my PCM is locked by a Fastchip tune. anyone know a way around this to flash it.. would like to have my car running again this weekend.. right now she is dying for this new tune so I can try the new blower kit I have on the car.
thanks in advance!
Chris
Old Mar 24, 2006 | 10:51 PM
Alvin@pcmforless.com's Avatar
Re: can an Ed Wright locked PCM be reflashed with tunercat?
I think you can just do a full re-write over and it should take care of it.
Old Mar 24, 2006 | 10:53 PM
Houdini's Avatar
No!!!
I had a "locked" Ed Wright tune on my PCM, my first attempt at a reflash with TunerCat fried my PCM. I ended up having to send the fried PCM to tunerCat so the tune could be recovered and the PCM repaired and unlocked.
Call or e-mail TC with your concerns, he will help you... A+ service!
Shea
Old Mar 24, 2006 | 10:55 PM
NC-LT1's Avatar
alvin,
thanks for the reply.. when you say do a rewrite, you mean just go ahead and program the file in instead of trying to read it first?
I can read the pcm with PCCOMM just fine but when I try and read the file with tunercats software it gets half way through connecting then throws a code stating "wrong message sent" I amguessing this is where the lock is coming in preventing me to read the tune in the PCM.
I will give it a try though and see what happened.. i suppose if it fries the PCM I will have to send it off anyways to get socketed.
thanks for your input!
Chris
Old Mar 24, 2006 | 10:58 PM
NC-LT1's Avatar
whoa.. ok.. guess not.. Houdini.I have written to TC, they said they did not know how to unlock the PCM if it was locked by ed wright... so I guess don't try flashing to PCM.. now what do I do?
CHris
Old Mar 24, 2006 | 11:55 PM
Houdini's Avatar
That's strange... they fixed that exact problem for me.
When I first used my TunerCat program on my T/A, all I could do was read the program, I could not reflash the PCM, I kept getting all sorts of errors. After the fourth or fifth attemp my PCM fried. I e-mailed TC with my problem and offered to send my fried PCM to him so he could look at it, he agreed. Along with the return of the repaired PCM was a explanation to why The PCM fried while using the TC tuning program. I don't recall the exact information, but it was something along these lines... "A glitch/bug occures in the TC program when it encounters a locked PCM, the glitch/bug causes the PCM to become fried. The bug in the software has been fixed, your PCM has been unlocked and original programing has been restored".
I had my restored and unlocked PCM back to me within a week, all was good... TC came through for me.
Old Mar 25, 2006 | 01:22 AM
NC-LT1's Avatar
I found another post explaining your situation and the resolution.. you were using OBDII, where as I have an OBDI car.. would there be a difference?
and I know it has been recommended, but has anyone successfully flashed over an Ed Wright locked PCM?
and if anyone has had an Ed Wright PCM that ws locked, were you able to read the PCM under operation with software for scanning such as PCM COMM? I am able to read this, but when I try and read with Tunercat, it sends the error message report "wrong message sent" I am assuming that this is the lock kicking in and not allowing me to go further. prior to receiving this message, my cooling fans turn on, a few lights on the dash illuminate just like it did when I used my first Hypertech program on another car letting me know it is communicating and getting through to the PCM.
I don't want to fry the PCM and find out an hour later I could have avoided it and have a feesible solution for tuning through or removing the lock, but at the same time, if there is some factual proof of someone who has flashed over a locked PCM, I would like to know about it.. I may give it a try.
thanks in advance!
Chris
Old Mar 25, 2006 | 09:43 AM
NC-LT1's Avatar
Update.. tried flashing in the new program and got the same scenario..starts communicating, fans turn on, a few lights come on the dash and then it says error report, "incorrect message sent" any takers?
thanks in advance,
Chris
Old Apr 5, 2006 | 07:36 PM
camz383's Avatar
Yes it can, I got a tune from Ion and it just overwrote my "locked" pcm, it is only locked to view, not write over...
88IROC_Z
Jul 22, 2015 11:38 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
dolfan324
Jul 17, 2015 10:34 PM
gelbza
Jul 12, 2015 08:10 AM
