Pcm Question!!!
Old Feb 23, 2006 | 10:10 PM
LUDA0840's Avatar
Pcm Question!!!
Can I run a ODB2 pcm on a 94 camaro that has a ODB1 Pcm?
Old Feb 23, 2006 | 10:38 PM
infinitebird's Avatar
Re: Pcm Question!!!
Yes.
Old Feb 24, 2006 | 07:31 AM
DirtyDaveW's Avatar
Re: Pcm Question!!!
??? You can? This is the first time I've heard that. Do you know anyone that's actually done it or do you have a forum thread where it's discussed?
Old Feb 24, 2006 | 07:39 AM
Re: Pcm Question!!!
People on this forum do it all the time. OBD-I > OBD-II or OBD-II > OBD-I. You do have to match your knock sensor to the OBD type. The crank position sensor is another thing to be considered, depending on which way you are swapping.
Old Feb 27, 2006 | 11:13 AM
madwolf's Avatar
Re: Pcm Question!!!
It can be done, but it is better to have it reprogrammed or you'll have SES lights and all sorts of things going on.
In fact, you don't need to swap knock sensors. If you leave your OBD1 knock sensor in, you will have disabled the knock sensor completely, so it will never pick up any knock. If you're OK with that, then you don't have to replace it.
DirtyDaveW
Dec 1, 2016 05:37 PM
94Form
Feb 10, 2015 11:23 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Injuneer
Dec 15, 2014 09:36 AM
dreamer1q
Aug 20, 2002 11:19 AM
