AIR/EGR delete question
Old Mar 16, 2006 | 08:40 AM
silverlt1ss's Avatar
does the car run smoother if the egr/air are edited out?
Old Mar 16, 2006 | 09:15 AM
Re: AIR/EGR delete question
You will not notice any difference.
AIR operates for about 2 minutes at startup to help heat the cat(s) up faster, then shuts off. It has no affect at all on idle, engine smoothness or engine power.
EGR only operates under conditions known to produce high combustion chamber temperatures. Doesn't operate at idle, doesn't operate above 3,500rpm, doesn't operate at WOT. Assuming the EGR valve is closing properly, it will not affect idle, engine smoothness or engine HP. It actually help reduce detonation under conditions like lugging the engine at low rpm in the wrong gear.
Noenav
Mar 1, 2019 07:38 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
alex5366
Mar 8, 2015 11:32 AM
alex5366
Feb 17, 2015 10:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
