Shift point problem.....
Old Feb 25, 2006 | 09:28 AM
TomsZ28's Avatar
I had a speed shop adjust my computer for the new gears I put in. He also changed some torque settings & fuel/air settings. He was using a laptop & some LS1 edit software. My speedo reads correctly now but when lightly accelerating, my car jumps through the gears. If I barely give it any gas, I am in 4th by 24mph. If I punch it from a dead stop, it shifts around 3000 rpm. The speed shop says someone has messed with my shift point tables & they will need to take another look at it. I never had the problem before. I switched from 2.73 gears to 4.10 gears. Does anyone know what could have caused this?
Thanks!
Old Feb 25, 2006 | 10:27 AM
TomsZ28's Avatar
Re: Shift point problem.....
Also, if I bought a Hypertech programmer or a LS1 edit package, would it still work now that my PCM is not stock?
Old Feb 26, 2006 | 12:23 AM
TomsZ28's Avatar
I am debating on buying the LS1 edit software... Anyone know what my shift settings should be at?
Old Feb 26, 2006 | 08:42 AM
Sounds like the speed shop is the one that messed it up. They should fix it.
Old Feb 26, 2006 | 11:41 AM
TomsZ28's Avatar
Kinda what I was thinkin'. The only thing I saw the guy do with my tranny was he said "do you want me to disable CAG" & then he noticed I have an automatic & said nevermind.... He did point out that my limit was set to 245mph. He stated that someone has been into the PCM before. I know that my 94' Z28 was set to 115 or so from the factory but I don't know what the 01's are set to.
Old Mar 1, 2006 | 10:52 PM
TomsZ28's Avatar
Well, the speed shop keeps blowin' me off.... I feel like driving my car through their friggin' garage.. Anyone know a good tuner in Colorado?
Old Mar 4, 2006 | 06:47 PM
TomsZ28's Avatar
FYI...
I ended up going to Dragon Racing. They are the best! The tuner that screwed up my shift points had also advanced my timing way too much & set my fuel curves incorrectly. The car runs better than it ever has.
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
number77
Sep 6, 2002 01:29 PM
96z
Sep 5, 2002 07:53 PM
