rs32 or usb cable?
Old Mar 6, 2006 | 06:13 PM
romoranger's Avatar
rs32 or usb cable?
just wondering what you guys would use. I keep trying to contact akm cables with the question but don't receive any responses. i was just going to use a desktop computer to hook up to it until i got a lap top, but i don't know if i need a rs32 or a usb cable. i am not quite sure what the difference in what the two is, i was hoping someone might be able to point me in the right direction.
Old Mar 6, 2006 | 08:06 PM
CompreSSor's Avatar
Re: rs32 or usb cable?
What are you suing to tune? If you have tuner cat you need a RS232 cable also called a serial cable. You only need a USB cable if you dont' have a serial port.....Then you would need a USB to Serial (RS232) converter.
Old Mar 6, 2006 | 08:11 PM
romoranger's Avatar
i am just going to use the freescan software to pull CEL's and the like. later on i may get lt1_edit just so i can load tunes from the tuners on this board. i am a little computer hardware illiterate, so i am not sure what each looks like or how it plugs in
i would hope the desktop i have would have both, or any laptop would have both as well as long as it was kind of newer
Old Mar 6, 2006 | 08:18 PM
CompreSSor's Avatar
actually a older laptop tends to have a serial port, They are kind of outdated. A usb is the small flat connector used on digital cameras and sutch. A serial looks almost the same as the plug for your monitor but with less pins (only 9). I use a serial cord.. (lt1 edit and Logworks both use serial) But with a USB to serial converter, becouse I don't have a serial port.
Old Mar 6, 2006 | 08:33 PM
romoranger's Avatar
oh, ok, i see. my computer has a serial port on it, i guess it would be advantageous to get the serial port then since more programs seem to be running it
Old Mar 6, 2006 | 08:36 PM
CompreSSor's Avatar
correct
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
Aug 24, 2015 06:41 AM
