Ecm Pin Help
Old Feb 22, 2006 | 01:05 PM
Prorac1's Avatar
Ecm Pin Help
I did a T-56 conversion in the camaro and am figuring out my wiring. I am hooking up the reverse lockout and i know i have to hook the B side of the connector to pin D6 (blue connector) on the ecm. Now i have to find a keyed hot. Do you think it would be easier to tap into the hot wire in the reverse light plug, or go up to the computer and tap a pin thats not used currently, but is a keyed hot. Thanks Prorac1
Old Feb 22, 2006 | 02:00 PM
rngilliland's Avatar
Re: Ecm Pin Help
When I converted my 94 I used the hot wire from the reverse lights for the reverse lock out solenoid.
I didn't have an extra pin to add a wire to my pcm so I moved the light green wire from spot #7 on the black connector to spot #6 on the blue connector and spliced into it at the connector that plugged into my auto trans.
Old Feb 22, 2006 | 02:45 PM
Prorac1's Avatar
Re: Ecm Pin Help
when i did the conversion, i grabbed the 6 speed harness, so i have it wired up like a stock m6. I have a friend that works at the dealer, so i have acess to the pins and pliers. But i think thats what im going to do, just tap the reverse light harness. Thanks, prorac1
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
