Programming for different tire sizes?
Do any of you guys run different size tires on the street then on the track?
I was thinking about doing it so not to wear out the ET Streets I am going to get soon. But I am not sure what might happen if I get it tuned for the taller tires for the track and run shorter on the street and so forth...
Or would it just be easier since I have the performance shift button to change my shift points for the taller tires only when that button is pushed???
Re: Programming for different tire sizes?
The size of your tires shouldn't affect anything in the programming except for speedometer/odometer calibration. Get it tuned based on your street tire size, set your shift points however you want them (and leave them that way for street and track), and be aware that your speedo may be wrong at the track.
he has an A4... shifting is not RPM based, but MPH based... so, his shift points will be messed up if he doesnt account for the size change.
Originally Posted by 1SlowFormula
This was my thought, but in looking into the tables I think I am just going to set it up for street tires for the constants yet adjust the shiftpoints when the performance shift button is selected to where they would do the best for the taller tires at the track... I just have to figure them out and that will be a lot of T&T's...
http://www.f-body.org/gears
Originally Posted by infinitebird
Use this web site, it will get you a ballpark figure that will be pretty close.
LOL, that's just funny and I will let you guess why...
On an entirely unrelated note, that's a nice sig you have there.
Actually both parameters (MPH & RPM) need to be met for the computer to comand the shift...
Originally Posted by steve9899
And if you don't touch the programming, both parameters (MPH and RPM) will be met at the exact same RPM as before.
care to enlighten me?
