a/f ratio hookup
Old Mar 13, 2006 | 08:25 PM
cardemo16's Avatar
Question a/f ratio hookup
i have a 94z and i just got a a/f ratio gauge the directions say to hook up 1 wire to the signal wire from the o2 sensor btwn the pcm and the o2 connector but where would i find this wire and i have 2 o2 sensors 1 in each manifold should i just weld in a new sensor on the y pipe to get the best reading ne help would b great
Old Mar 14, 2006 | 12:22 AM
96HawkCnvt's Avatar
Re: a/f ratio hookup
Easiest would be to connect to the wire at C8 or C20 (that is the clear connector on the PCM, either cavity 8 or 20) Wire color will be purple for C8 and purple/white for C20. If you use one of those then you can easily run it into the interior through a relatively large rubber grommet that is right behind the PCM.
Alternatively, you can find these same wires at the connector for each O2. Just make sure you connect to the harness side, not the O2 side of that connector.
Note: this type of A/F reading will NOT be accurate. It will be accurate at or near 14.7 to 1 (Stoich) but can not be relied on for WOT tuning. Only a wide-band setup will work for that.
Todd
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
Henson071
Dec 30, 2015 09:55 PM
Z Power
Sep 19, 2015 11:19 PM
Henson071
Aug 4, 2015 09:32 AM
