Larger throttle bodies...
Old May 7, 2006 | 08:43 PM
Z28Quetzal's Avatar
Guys,
I am sure you all can probably explain this to me: suppose you have a fuel injected engine, stock cam, stock computer, and headers.
Suppose you remove the smaller throttle body and replace it with something bigger. This would allow the engine to breathe better, yes?
So, given the above scenario, would the engine run like crap? Would it perform pretty decent? I have read already that an engine is an air pump. It will only 'breathe' what it needs. BUT, with the bigger throttle body it will breathe a little better at higher RPM's, right?
I realize that to get the full bang for the buck you would have to do all the other mods such as a cam and endless other things. However, am I pissing in the wind or is a bigger throttle body something that might help a 'restricted' engine?
any help would be appreciated...
thanks,
joe
Old May 7, 2006 | 09:43 PM
my94blackz's Avatar
Re: Larger throttle bodies...
I lost .5 RWHP, going from a stocker to a BBK 52MM. This was 2 consectutive pulls on a dyno.
Old May 7, 2006 | 11:02 PM
OrbitalChris's Avatar
yeh.....definitely get some other mods first, it wouldnt do much without them. good luck
Old May 7, 2006 | 11:19 PM
Speed_Kills's Avatar
Cam, LT's, CAI, ported Intake manifold before bigger TB
Old May 8, 2006 | 01:17 AM
Bersaglieri's Avatar
I hope if your taking off the intake manifold your taking it off to port and polish the heads. The HP gain from porting the intake manifold would probably be just as unnecessary as with the TB. At least on an LT1.
-Dustin-
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
surreybrad
Sep 29, 2015 09:00 PM
KYWes
Sep 26, 2015 08:49 AM
Sep 17, 2015 11:53 AM
