Roller springs vs Flat tappet springs
Old May 16, 2006 | 02:18 PM
MichiganSkip's Avatar
Can a head set up for max .520 lift w/flat tappet hyd cam be used with a hyd roller at same lift safely. If not, why?
Old May 16, 2006 | 08:22 PM
MachinistOne's Avatar
Re: Roller springs vs Flat tappet springs
Different spring pressures are needed. Flat tappets run anywhere from 95-115 on the seat and up to 280 open, hyd roller needs 120-150 seat and 295-330 open depending on ramp rates. Spring setups for mechanical flat tappet and hyd roller are similar.
Old May 17, 2006 | 08:12 AM
contactpatch's Avatar
roller cams, allow higher ramp rates,
so, in general, if the cam design takes advantage
of the benefits of the roller,
higher spring pressures will be needed.
every cam has recommended spring pressure
and rpm limit
Old May 18, 2006 | 07:59 PM
Stephen 87 IROC's Avatar
If it's a billet cam then higher spring pressure can be used. If it's a cast cam, stick to the recommended spring pressures. Too high an open spring pressure on a cast cam can break it.
Roller cams always want higher spring pressure than a flat tappet cam. If your springs are designed for a flat tappet and you're switching to a roller, you should be changes valve springs.
Old May 19, 2006 | 06:43 AM
Thanks guys
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Jan 22, 2015 12:17 AM
InfernalVortex
Jan 17, 2015 09:35 AM
