Engine design
Old Apr 29, 2006 | 02:38 AM
disco192's Avatar
Engine design
I was talking to a friend about target RPMs for given engines and got to thinking.
So every part of the engine is pretty much designed around a target RPM that it operates best at. For example, you would have a target RPM for an IVC for a given port knowing the intake velocity at that point.
When you design a motor for a broader RPM range, what kind of sacrafices do you make to achieve gains at given points vs others?
Would you design your exhaust to run best at a lower RPM or intake... or would you target them all at the same RPM and screw the rest?
I am not sure I am asking this the right way, but I dont want a simple answer like "area under the curve"... because that is obvious.
Are there certain components that have a broader range than others that are more responsive than others?
I am just trying to piece this all together, because it kinda sparked my curiosity (at 2AM). It almost seems like a flat TQ curve wouldnt be the best, because there would have to have been sacrafices made at some point to accomidate.
I know I might be asking for build secrets (or maybe not) that come from years of experience, but hell... its worth asking.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 27, 2015 06:27 AM
guionM
9
Aug 29, 2002 01:48 PM
centric
Aug 15, 2002 09:04 PM
