can someone answer these questions for me
Old May 26, 2006 | 01:01 PM
jasonisdn's Avatar
http://web.camaross.com/forums/showt...=433880&page=7
Old May 26, 2006 | 01:41 PM
OldSStroker's Avatar
Re: can someone answer these questions for me
Which specific questions?
Paragraphs and punctuation are your friends.
Old May 26, 2006 | 01:44 PM
jasonisdn's Avatar
ok i spent about1 hour reading this (and this needs to be a sticky for real) tell me if i have gotten the wrong idea.
396 500na hp, 300 wet shot (125 dry for now) stock fuel feed and return lines will work, no issues.
wire 1 pump to the fuel relay the way it is now , no change. the second pump should have a new 12 volt source from ( lets say my nitrous switch) something, maybe an addition switch (relay) straight from the alt or something like that.
ok then they can share a ground wire the size of texas. 1 pump runs in the na no nitrous mode all the time, if said pump dies you can arm switch and run second pump to get home or whatever. now in race conditions , all you have to do is arm the nitrous switch or secondary switch and the second becomes usefull and ready to give you enough fuel to be safe.
ok if any of that is wrong please let me know my brain is fried and cant take anymore reading. oh yeah where in the hell are you getting the hoses for the inside of the take and the block that is joining the 2 pumps into 1 feed line.
if there are part numbers that i missed can someone please type them in the reply so i can copy it and start to order some junk.
also what size injectors would i need casue i was told by thunder racing that 50 was over kill , remember i am running the dry shot untill i can afford the wet shot. so say 625hp the injectors must feed right off the bat.
Old May 27, 2006 | 07:41 PM
I think you're asking the people in the Forced Induction forum thread to confirm or correct your interpretation of the construction of a fuel system. Not sure what anyone here on Advanced Tech can tell you without going through the 7 pages that took you an hour to read.
I'd suggest to take your retyping of you post, copy and paste it into an "edit" of your first post on the FI forum, and see if you get any results. You probalby didn't get any repsonses the first time since it was almost impossible to follow the first post.
Old May 28, 2006 | 01:35 AM
jasonisdn's Avatar
i was hoping a few that were involved in the topic would just say yes or no to the questions, but i guess not. i found another 8 page write up that answered it all. thanks for point me in a direction though inj
grgguy
17
Feb 23, 2015 07:57 PM
heavenly_six
Dec 10, 2014 12:23 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
redzed
Sep 4, 2002 06:22 PM
Brent94Z
Mar 21, 2002 04:44 PM
