Hellfire Rings
Old Jun 11, 2006 | 08:01 AM
joe-96z1le's Avatar
Hellfire Rings
Do Hellfire piston rings contribute to or cause excessive cylinder wear?
If so, what would be a ballpark estimate on the amount of mileage (street with limited track time) I could put on a FI Stroker motor before a re-bore/ ring job would be necessary?
Old Jun 11, 2006 | 08:13 AM
jonathan_abilene's Avatar
Re: Hellfire Rings
what material is it made of? I'm talking about the top "compression" ring?
Never heard of hellfire... I'm thinking of buying some Total Seal rings or maybe the company that is owned by AE Clevite, its called Perfect Circle Automotive.
Old Jun 11, 2006 | 01:53 PM
rskrause's Avatar
Moderator
Re: Hellfire Rings
It will break before bore wear becomes a problem
Rich
Old Jun 11, 2006 | 07:11 PM
joe-96z1le's Avatar
Re: Hellfire Rings
That's what I suspected but I hope that's not the case.
Speed-Pro makes HellFires, a hardened, tempered alloy with a plasma-moly facing.
Supposed to help with cylinder sealing under extreme pressures.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
Catmaigne
Jul 14, 2015 05:17 PM
