Taste Test...
Old Jan 19, 2006 | 03:09 PM
The Big Show's Avatar
Taste Test...
Thought I'd give you guys a taste test. Brought the motor home and mocked it up on the stand. Had some life changes just recently but hopefully I'll have it in the car and on the dyno pretty soon....
Old Jan 19, 2006 | 03:15 PM
marshall93z's Avatar
Re: Taste Test...
Awesome!!
Is that a Super Victor, or no?
Old Jan 19, 2006 | 03:31 PM
Re: Taste Test...
Originally Posted by marshall93z
Awesome!!
No, not a super vic. It's a dart wilson. Still an off the shelf piece but it was the ONLY off the shelf piece that had a flange big enough to work with.
Old Jan 19, 2006 | 04:12 PM
PUR_SSYN's Avatar
Re: Taste Test...
That looks like a good bit of work! Nice cylinder heads and collectors to boot.
How similar are the ports to an LT5 head? I see 4 injectors per bank, as opposed to eight.
Any photos, or MFG links for those heads?
Old Jan 19, 2006 | 04:30 PM
Re: Taste Test...
They are nothing like an LT5 head. These heads still use pushrods and use a forked rocker to actuate two valves at one time. There are 8 injectors that will sit underneath the rails, I just decided not to put them in.
Here's the manf's website: Arao Engineering
Old Jan 19, 2006 | 04:35 PM
number77's Avatar
Re: Taste Test...
We must have a video, with audio. I've never heard anything like what you've built. What RPM range are you going for power?
Old Jan 19, 2006 | 05:02 PM
Re: Taste Test...
My friend is going to come to the dyno tuning session with me and will have video as well as pics so no worries. I don't plan to turn much more than 7K.
Old Jan 19, 2006 | 05:14 PM
LJ93Z28GM's Avatar
Re: Taste Test...
Forever had ended that is how long the mythical 32 valve heads to make it into a running car.
Hope it puts down some nice numbers.
For all the money you have in the bad boy I am suprised you did not clean or dress it up a bit more, but then again it is a daily driver.
That is the only setup worthy of having a clear valve cover so you could see what really goes on to move all the internals
Old Jan 19, 2006 | 07:13 PM
1racerdude's Avatar
Re: Taste Test...
If it's going in a Camaro a crab cap will help with clearance.
Old Jan 19, 2006 | 07:41 PM
rskrause's Avatar
Moderator
Re: Taste Test...
Damn, that is positively lascivious! DROOOOOOOOOOOOOOOL.
Rich
Old Jan 19, 2006 | 07:51 PM
Re: Taste Test...
LOL...it has been a long time coming. The day after I took it home, my engine builder called me and said he panicked for a second when he opened the shop that morning because my motor wasn't sitting there for the first time in like 3 years. Craziness....As far as dressing it up, thats not my style and just never has been. I'm more about function over form. You can mess with the pretty stuff once it's all together and putting down consistent numbers. If I bling'd it all out and then it blew up on the dyno, that would just be more wasted money
Actually clearance isn't an issue with this particular setup.
Rich\
LOL...thanks Rich. Thats a new one so I'll log it fo'sho
Old Jan 19, 2006 | 08:58 PM
N20Dave's Avatar
Re: Taste Test...
Looks really good! That will get some attention when you open the hood.
Old Jan 19, 2006 | 11:11 PM
unstable bob's Avatar
Thumbs up Re: Taste Test...
Well, looks like the end result is in sight.
Glad to see somebody finally fire up a Dominion 32V equipped engine, even if it isn't me.
Old Jan 19, 2006 | 11:28 PM
OldSStroker's Avatar
Re: Taste Test...
Did you get a Care package at your side door today, UB? Maybe a couple of refrigerator doors?
Old Jan 20, 2006 | 08:50 AM
Re: Taste Test...
Just make sure you DON'T give up like we both almost have numerous times. It's almost hard to believe that this thing is done...
