VersaFueler
Old Mar 28, 2006 | 02:37 PM
xxsaint69x's Avatar
VersaFueler
anyone using it? I just bought one and it didnt come with any instructions how to hook it up....seems like there are tons of wires to splice thats for sure....
Marcin
Old Mar 30, 2006 | 03:37 PM
marshall93z's Avatar
Re: VersaFueler
Is this the impedance converter?
Old Mar 30, 2006 | 06:54 PM
thesoundandthefury's Avatar
Re: VersaFueler
http://www.acceleronics.com/instructions.htm
Old Apr 5, 2006 | 01:46 AM
blown383's Avatar
Re: VersaFueler
Marcin
Make sure your wires are color coded correctly. My Versafueler had some wires mixed up and Im waiting for an email from LJ to solve the problem.
-B
Old Apr 5, 2006 | 09:26 AM
xxsaint69x's Avatar
Re: VersaFueler
what do u mean?
Old Apr 5, 2006 | 09:57 AM
blown383's Avatar
Re: VersaFueler
I'll post a pic once I get home and you'll understand.
-B
Old Apr 5, 2006 | 11:45 PM
xxsaint69x's Avatar
Re: VersaFueler
please do, i am goin to splice that sucker in tomorrow
Old Apr 6, 2006 | 02:03 AM
blown383's Avatar
Re: VersaFueler
Here you go
If you notice the wires don't match up... so I contacted LJ and he said that it was a simple fix since all of the wires going in and out are the same... just that they have to match up. So I just need to rearrange the wires to match and Im set! Speedy reply too!
-B
Old Apr 6, 2006 | 11:14 AM
xxsaint69x's Avatar
Re: VersaFueler
just checked mine and everything looks good, btw which wire are u going to hook up the power wire to? Will the fuel pump control wire work (its in the same plug as the injector wires)
Marcin
Old Apr 6, 2006 | 11:18 AM
blown383's Avatar
Re: VersaFueler
Marcin
LJ said to just use a switch power source and that the box doesn't have to be fused because it hardly draws any power at all.
-B
Old Apr 6, 2006 | 11:13 PM
xxsaint69x's Avatar
Re: VersaFueler
spliced it all in today, still dont know where to connect the power wire...some one give me a good idea, id prefer it to be in on of the Plugs that go into the pcm as i already spliced everything there....
Marcin
Old Apr 9, 2006 | 12:04 AM
xxsaint69x's Avatar
Re: VersaFueler
anyone?
Old Apr 10, 2006 | 12:32 AM
xxsaint69x's Avatar
Re: VersaFueler
got it working
Old Apr 10, 2006 | 01:26 AM
blown383's Avatar
Re: VersaFueler
cool! Where did you connect the power switch?
-B
Old Apr 10, 2006 | 03:22 PM
xxsaint69x's Avatar
Re: VersaFueler
ignition switch
DirtyDaveW
May 19, 2014 12:55 PM
bucket77
Jan 7, 2012 01:50 AM
jrcanc
Jun 2, 2011 07:00 PM
jasonisdn
Aug 16, 2007 09:36 PM
LameRandomName
Sep 30, 2005 06:25 AM
