Is this normal for oil psi in a 383?
Old Apr 28, 2006 | 08:14 AM
Gripenfelter's Avatar
Sorry, I have a Camaro dash with no markings for oil psi.
When I had a Melling high volume pump in my 383, the oil psi sat at the halfway mark at idle (pointing straight up).
After my last rebuild I went with a standard volume pump. The oil psi was at the 1/2 way mark for the 30 min break in but since then it has always been at the 1/4 mark at idle which is where it used to be when it was a stock 350.
Does this sound about right?
Old Apr 28, 2006 | 09:09 AM
GetaZforgetGT's Avatar
Re: Is this normal for oil psi in a 383?
Which pump did you run?
Does it have the high pressure spring in it?
Mine supposedly came with the "white" high pressure spring but to one installed in mine is yellow.
Old Apr 28, 2006 | 10:05 AM
84firebird's Avatar
my oil gauge points down...... lol
how's the gauge scaled? like i have no idea what psi you are even running, need a regular oil pressure gauge?
350s and 383s generally run 20 min at like low idle and 40 is usual, rebuilt with high vol pump, like mine, gets up to almost 100
Old Apr 30, 2006 | 12:55 AM
BADST95's Avatar
What oil filter are you using?
Old May 2, 2006 | 08:32 AM
I'm using the long Wix oil filter with a standard volume Melling pump.
Old May 3, 2006 | 01:59 PM
Did you give your engine builder a call to see what they think about the issue?
Old May 3, 2006 | 03:09 PM
It was his first time doing an LT1. He's done countless SBCs and they make huge power reliably.
He didn't seem concerned.
Old May 3, 2006 | 03:50 PM
Did he by chance tell you what he set the bearing clearance at?
Old May 3, 2006 | 07:47 PM
First 4 main journals: around 3 thousandths. Last main journal: around 3 1/2 thousandths
Old May 4, 2006 | 07:37 AM
1-4 are a little more loose than some like but still in spec and I don't think its going to be a problem...5 is within spec.
What weight oil are you running or did the builder recommend a weight to you?
The more I think about it...everything seems right. The "12 o'clock position on the gauge is 80 psi....so if the needle is between straight up and flat then you'd be at about 40 psi which is good. Even 30 psi is still good.
Old May 4, 2006 | 08:39 AM
Thanx dude.
I'm running 10W40 dino oil right now. I want to put on 3000 miles before switching to Mobil 1.
Old May 4, 2006 | 11:08 PM
mebanditws6's Avatar
The "white" spring on the same engine setup will not affect pressure at idle and lower engine speeds when the oil is hot and thinned out. That has strictly to do with bearing clearances and the weight of the oil. At higher engine speeds and above ~55psi, the white spring will generate more pressure then the stock spring.
Jason
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
drptop70ss
Mar 26, 2015 01:50 AM
transam_388
Mar 15, 2015 11:53 AM
jayblev95
Dec 1, 2014 06:55 AM
