Resleeve No4 cylinder?
Old Mar 27, 2006 | 10:46 PM
Viking's Avatar
Is it possible with good results on a supercharged engine?
How much oval will cyl.no. 2 and 6 be?
/N.
Old Mar 27, 2006 | 11:03 PM
Josh'95Z28conv's Avatar
Re: Resleeve No4 cylinder?
/N.
I was told my a local racing engine shop that sleeving a block is no problem. I dont see a problem in it either, as long as its done right.
How much oval
Old Mar 27, 2006 | 11:07 PM
Viking's Avatar
oval = not round
Because the press the new sleeve down, it will affect the other cylinders shape and they will probably get oval...........the question is how much, and will it affect?
Old Mar 27, 2006 | 11:13 PM
oval = not round
Ahh. Id assume the sleeve will be pressed in before boring and honing. If the cylinders did get a little egg shaped, that would be fixed when it is honed and/or bored.
Old Mar 27, 2006 | 11:18 PM
Viking's Avatar
I dont want to change my pistons so I will ahve the same bore as before maybe just honing the cylinder?
Old Mar 31, 2006 | 05:50 PM
ronbros's Avatar
I have sleeved all 8 cylinders on chevy 350s, but I used sleeves that had a shoulder at the top and a counter bore in the block, I believe it makes a stronger top deck. most sleeve operations put the shoulder at the bottom of the bore and th sleeve sets down to the shoulder, but the top deck then can start to flex,lose gasket seal, especially at 40 psi boost. that said if you are going to get serious a better block might be considerd. thanks RON
Old Apr 2, 2006 | 11:45 PM
Viking's Avatar
The block is a Motown.... No4 cyl has cracked below the piston, when the piston is at the bottom you could see the crack just above the top...
Will take it to a enginebuilder and see what they says about it.........
/N.
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
