Micrometer question
Old May 3, 2006 | 10:38 PM
SWINGRRR's Avatar
Micrometer question
Whats a good "feeling" on how the known blank should fit to calibrate the micrometer? I have is set to "0" when I can just barely slide the blank in and move it around, but it wont wiggle in-line with the sleeve and thimble.
I know how to read the measurement, but there are no write-ups I can find on the net to calibrate it?
Old May 3, 2006 | 10:54 PM
MachinistOne's Avatar
Re: Micrometer question
Is your mic not a friction or ratchet style?
It should be able to slide in/out without force IF you are perfectly parallel with the centerline of the anvil. There should be a very slight resistance or friction.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
