AFR or Brodix
Old Mar 15, 2006 | 11:38 AM
Lab's Avatar
Lab
AFR or Brodix
90 Vette, building a 406.
AFR 210 (or 220) or Brodix 18 degree heads? With the brodies you can run standard 23 degree valvetrain stuff.
The cam will be matched to whatever heads I get. Stock 2 bolt block with Eagle 5.7 rods, SRP pistons, etc.
Local racer offered me a really good deal on some used Weldtec Brodix 12 heads. But these heads are overkill from what I have gathered.
Lance
Old Mar 15, 2006 | 12:06 PM
SStrokerAce's Avatar
Re: AFR or Brodix
Ok, stock 2 bolt block? You gotta start rethinking the build or just dial it WAY back on heads.
You are missing out on some other good head choices by not looking places other than AFR and Brodix IMHO.
Bret
Old Mar 20, 2006 | 03:48 PM
Lab's Avatar
Lab
Re: AFR or Brodix
Yea, its a 2 bolt, stock 406 crank. Nothing real serious. Something better than that L98. I would like to use converted carb or LT1 intake. The L98 intake (edlebrock base + Lingenfelter runners) ran out of breath on the stock engine with ZZ3 cam and Trick Flow heads.
I thought the AFR 210/220's were the head of choice for this type of motor.
Thanks for the input
Lance
Old Mar 20, 2006 | 06:07 PM
AutoRoc's Avatar
Re: AFR or Brodix
What's it used for? This sounds not very advanced tech. Street/Strip guess would be to do some 210's and a vic jr converted. Edelbrock sells the EFI converted Vic jr intake I believe. Might even have the throttle body, fuel rails, etc with it.
Either way, the words WeldTech and 2 bolt main don't belong in the same post.
Old Mar 20, 2006 | 07:22 PM
Brettinator's Avatar
Re: AFR or Brodix
Bret
Second that motion, was sold on AFR 215s on my Aug setup but have reconsidered some other options for the goals I've targeted on my build.
Old Mar 20, 2006 | 08:34 PM
sprayedtransam's Avatar
Re: AFR or Brodix
2 bolt 400 blocks are stronger than 4 bolt 400 blocks I believe. Kinda backwards sounding, but it seems like that is the case.
Old Mar 20, 2006 | 08:52 PM
Re: AFR or Brodix
gotcha...I wasn't thinking that far ahead
I was just thinking about stock 2 bolts compared to stock 4 bolts. Continue the advanced tech discussion
Old Mar 21, 2006 | 01:22 PM
Aaron91RS's Avatar
Re: AFR or Brodix
afr 227's with about 600 lift should do the trick
you want something mild ~420hp I have some Trick Flow TW G2 heads that are ported for $1000 I run on my 406
Old Mar 25, 2006 | 04:09 AM
camarolover20's Avatar
Re: AFR or Brodix
What about the track1 stuff?
Old Mar 28, 2006 | 05:26 PM
Lab's Avatar
Lab
Re: AFR or Brodix
Intended use is all around. Joined NASA in Florida. Would like to do road race venues for fun. Fun car to drive on the weekend. That sort of thing.
Lance
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
FryedClutch
Sep 1, 2015 08:24 AM
bunker
Aug 21, 2015 10:21 AM
