advanced missfire
Old Jun 19, 2006 | 03:54 PM
Sylvrls1's Avatar
advanced missfire
if your engine is running fine in first gear but not 2,3,4 I am gonna guess you have an auto trans and that you have a prob with the trans and not the engine. does your engine idle and rev fine in park or N? your engine is not going to only have problems in a select gear and not the rest your engine will have problems a any given rpm no veh speed.
Old Jun 19, 2006 | 04:08 PM
Re: advanced missfire
Are you asking a question or answering someone else's post?
Old Jun 19, 2006 | 04:33 PM
predator's Avatar
you could have a bad plug wire and with more load on the engine in the higher gears resistance increases in the cylinder and it arcs more to the engine under load......
Old Jun 21, 2006 | 06:33 PM
simzjr's Avatar
sylvrls1=> thank you very much for your reply....however it is a standard transmission. please see my solution to the problem below
predator=> thank you for your reply:
wow am i embarassed to write this...
I started missing terribly on one cylinder today, like never before. Even when cold. So I pulled over and on a whim (desperate last attempt ) checked all the spark plug wires. They were all fine but one felt a little weird.
I pulled it completely out and inspected it. I then put it back on and got the satisfying "click". But something wasn't quite right with it, so I pulled it out again, and tried again.
It was then that I realized that the click was coming from the boot clicking into the spark plug metal heat shield and not the spark plug. This particular boot was manufactured 3/8" shorter than the rest of the boots and the metal protector prevented it from completely clicking onto the spark plug.
What bad luck eh? So i bought one new spark plug wire and it fit perfectly. Talk about a minor manufacturing error costing $$$ and major headaches!!
Not your every day problem. Its just funny and adds insult to injury as I tried looking at the wires many times before I realized it was clicking onto the heat shield and not the plug.
So it goes to show that you can't trust even a simple brand new part to be accurate.
Thanks for all your help everyone!
Old Jun 22, 2006 | 11:41 AM
predator's Avatar
yeah i had a prob like that but mine was arcing from the alternator braket to the drive belt lol and it wasnt a dead miss it only did it at low rpm heavy load
nosliw
Mar 9, 2016 04:56 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
