The SB2 LT1 lives
Old Jun 18, 2006 | 11:39 PM
N20Dave's Avatar
The SB2 LT1 lives
Just giving an update. Finally after 20 months it moves uder it's own power. I have a buch of things to do yet but it's downhill from here...I think. How do you think it sounds?
http://media.putfile.com/It-Lives-46
Old Jun 19, 2006 | 12:23 AM
MachinistOne's Avatar
Re: The SB2 LT1 lives
Old Jun 19, 2006 | 01:45 AM
1racerdude's Avatar
Good Deal.
Let us know how it is after ya get it sorted out.
Old Jun 19, 2006 | 04:36 AM
SABLT194's Avatar
Sounds good Dave! When's the maiden voyage to MG??
Steve
Old Jun 19, 2006 | 08:48 AM
MEAN LT1's Avatar
She sounds good. Need more footage and a windsheild!
Old Jun 19, 2006 | 10:39 AM
Colin91Z's Avatar
Old Jun 19, 2006 | 11:33 AM
Sparkz28ss's Avatar
God....is that you?
Old Jun 19, 2006 | 03:39 PM
Rice Killer87's Avatar
Sounds sweet man.
Old Jun 19, 2006 | 06:00 PM
Clean97Z's Avatar
That sounds awesome.
Old Jun 19, 2006 | 06:40 PM
ChrisUlrich's Avatar
Umm... can you please tell me how I get one of those? For real... that sounded absolutely ridiculous. I would love to know what you have done to that thing in detail! Any lists in the forums?
Old Jun 19, 2006 | 08:11 PM
96speed's Avatar
What kind of mufflers are you using. Its MUCH quieter and smoother idling than I would have anticipated. Not a bad thing, at all .
Ryan
Old Jun 19, 2006 | 10:20 PM
jerminator96's Avatar
He's using mufflers???
Old Jun 20, 2006 | 01:11 AM
N20Dave's Avatar
Thanks guys. I appreciate the compliments. There is no listing in detail in any other forums so I guess I'll lay it out here since it is fairly "advanced" in nature.
396 ci LT1 block with billet 4 bolt caps filled to the freeze plugs with block filler.
Callies Magnum crank
Oliver billet 5.85" rods
Diamond SB2.2 13.5-1 pistons with offset pins, nitrous ring package, friction coated skirts
Cam Motion solid roller for SB2 with a 4-7 swap 270/280 @ .050 .690/.710 113 lsa
Isky Red Zone offset lifters
Smith Bros pushrods
GM SB2 heads converted to reverse cooling, 287cc runners, 48cc chambers, 379 cfm I / 260 cfm E @ .700, 304 cfm I @ .400
Del West Ti valves 2.15/1.65
T&D shaft rockers, 1.8 I / 1.7 E
Accel Gen 7 dfi, Accel dfi distributor, 83lb injectors
SB2 resrictor plate intake, Accufab 2200 cfm throttle body
Lemons headers 2" primary / 4" collector
Spintech dual 4" oval with Spintech 4" oval shootout mufflers countersunk into custom pockets in the floor under the seats. Turndowns
Motor makes 740 @ 7900 and 520 lbft @ 5200 on the engine dyno. It makes 500 lbft from 3500 to 7000. Ignition cutoff is 8600
NX system with STD nozzles in each port, super shark N2O solenoid / two big iceman fuel solenoids. Two double billet rails, -6 feed line, two 15 lb bottles, FJO controller Currently jetted for a 200 hit at the wheels, after testing and chassis sorting it will be 350 at the wheels.
Mcleod LS1 blow proof bellhousing, push type twin disk clutch, G-Force built T56 with 9310 alloy internals, 30 spline output, viper front plate and custom spacer for a standard LS1 throwout bearing.
Old Jun 20, 2006 | 05:39 AM
ninety4camaro's Avatar
damn, that thing sounds great.
youve put alot of time and money in that thing
Old Jun 20, 2006 | 08:11 AM
eh....I guess if thats all you can handle....
