Timing chain q
Old Mar 3, 2006 | 01:17 PM
84firebird's Avatar
Timing chain q
Hey, I've got a double roller timing chain from melling i believe got just a few thousand miles on it. At present, I just swapped my cam, and when i bolted the timing chain back up, there's some slack in it, fresh rebuild going on a couple thousand miles (maybe 4000 at most) and i wanted more power so i put in a newer lunati cam grind....
It's a 350 bored .030 compression at 9.34-1 cranking is 165 psi (yea the cam has a pretty late closing intake valve), all the parts checked out fine on the topside...however...
If i remember correctly, that chain is supposed to be tight, and it's currently got a good couple degrees of play.
is it just a case of pos defective part? that's what i'm banking on, but then who do i go through for a new double roller timing chain?
thanks for the input
Old Mar 3, 2006 | 02:11 PM
PUR_SSYN's Avatar
Re: Timing chain q
I would suggest degreeing the cam to determine the play in the timing chain and remainder of the engine setup.
If I was to give you a visual, the chain should deflect about an 1/8" - 1/4" when applying pressure between the gears.
Old Mar 3, 2006 | 05:50 PM
84firebird's Avatar
Re: Timing chain q
hmm, okay, I'll head into the garage and check that, I dont think it was deflecting a full 1/4", mainly i just noticed it was deflecting and got worried cuz i didnt remember any deflection.
thanks man
Old Mar 3, 2006 | 07:57 PM
Damon's Avatar
Re: Timing chain q
Chains always stretch some in use, even if it's only for a short time. Cheap chains stretch like salt water taffy, higher quality chains stretch a lot less. Pre-lubing the chain before you install it helps reduce the stretch- lots of it happens when you first fire up a fresh motor.
Old Mar 4, 2006 | 07:10 AM
cehan's Avatar
Re: Timing chain q
You know, chain stretch was one of the things I was thinking about when I degreed my new cam in and found it to be 2 deg retarded. I installed a 2 degree offset crank key and then found that it degreed in at 1 deg advanced ( ). Anyway, I left it at that because I figured that as the chain stretched over time it would tend to retard the cam timing and bring it closer to the design intake centerline. Does that seem reasonable?
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
