heads
Old Jan 12, 2006 | 02:42 PM
cc89formula's Avatar
heads
can someone explain sb2.2 heads to me? also what about 18* and 15* heads? what has to be changed to run any of these heads? good for a street motor? thanks in advance
Old Jan 12, 2006 | 03:31 PM
96speed's Avatar
Re: heads
Ryan
Old Jan 12, 2006 | 04:06 PM
sheppard00's Avatar
Re: heads
there are several differances between the sb2.2's and even some of the 18 and 15 deg heads.. they can be good on the street but I would recomend a big ci small block.. on all three choices they will require special intakes, and headers. I'm not shure about acc bolt holes. there are a lot of people on here that know more abut those then me someone should post.
Old Jan 12, 2006 | 05:58 PM
Mindgame's Avatar
Re: heads
http://nascarheads.com/chevy_heads.html
Scroll down the page and there's a brief list of specifications for the 011, 021, 559 & 560 heads. Pay attention to what you're buying should you decide to buy used stuff.
With the 18 & 15* heads you will need special pistons, shaft rockers, intake manifold and headers.
The 2.2's will require all that along with a sb2.2 specific camshaft. Of course the studs and other hardware are different as well.
-Mindgame
Old Jan 12, 2006 | 07:59 PM
SStrokerAce's Avatar
Re: heads
If you want the more basic answer than what you have so far....
18° and 15° heads have a valve angle that is that far off perpendicular (from the deck) tilted towards the intake or center of the motor.
SB2.2 heads are 11° x 4° on the intake and 8° x 0° on the exhaust.... The x 4° on the intake means that it's also tilted away from the bore 4° so it's a canted valve head, just like a Ford Cleveland or Big Block.
Bret
Old Jan 12, 2006 | 09:22 PM
Re: heads
oohhhh ok, well then these arent for me. i was looking for something a little more budget friendly and had head about these heads, just didnt know anything about them. thanks for the answers everyone.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
